help with installing timing chain 1999 Dodge 3.3 L flex fuel
I am having problems installing my timing chain correctly what marks do I use for proper alignment does anyone have a visual diagram an instruction to please help!!!!!!!!!
if your old chain is still on, you should rotate the engine to where the circle/dots line up.
if you've already removed your old chain, simply put the new chain/srockets on without rotating the engine any. because the shafts are keyed, it can really only go one of two ways, and that's where the dots are important.
Found to be bent push rods
