help with code p0353
Old Apr 29, 2010 | 03:42 PM
momsvan's Avatar
momsvan
Default help with code p0353
02 caravan engine code p0353 states ignition coil c primary/secondary circuit malfunction ? is the coil bad or is it the wiring. it starting to run bad like it did last year and found that the fuel injection harness was fried. replaced harness was running good till last week the started all over again with running bad
Old Apr 29, 2010 | 04:03 PM
Tizzy1's Avatar
Tizzy1
It could be either. The harness likes to rub through on the corner of the head.
