Help! speedometer and half of gauges not working
I got into my van this morning and even before I put the key in, the d3l lights were on as well as part of the numbers in the odometer. The speedometer is at 10 and not moving. I tried to restart the van, but it didn't help. I don't know what else to do. I need my speedometer! PLEASE HELP
1998 grand caravan
1998 grand caravan
There is a good possibility that the printed circuit board on the rear of the cluster has failed. Sometimes if you power them down they kind of reset. Try disconnecting the battery ground for 10 - 15 minutes and then reconnecting it. Otherwise it will need to be replaced by a dealer because it needs to be calibrated when it is installed.
