Having A/C issues...electrical??
Old May 20, 2010 | 05:08 PM
Tizzy1's Avatar
Tizzy1
What do you have for tools Kim? I can walk you through some things to check, just need to know what you have available and we can go from there.
And I'll bet your water pump is leaking, it is very common for the pumps on the minivan's to leak. It usually leaks while the vehicle is running and it drips onto the axle shaft and gets flung around so you wouldn't see it drip on the ground.
