Need part # for aluminim plate behind the timing chain on a 98 Carvan 3.3L
Old May 13, 2010 | 01:19 PM
captwasabi's Avatar
captwasabi
Default Need part # for aluminim plate behind the timing chain on a 98 Carvan 3.3L
Hello Dodge fans.
I've got a 98 Carvan with the 3.3l v6. Coolant is leaking and the mechanic is telling me the leak is coming from one of the two nipples on the aluminum plate found behind the timing chain. Since the nipples are pressure fitted in I am told I need to replace the entire plate which has been priced at $700.
Search as I may I cannot seem to locate that particular part on any OEM website.
Any chance anyone here knows where I can:
  • Obtain the part number and/or name for this particular part, or
  • Check prices for this part online?
Any assistance would be greatly appreciated.
***EDIT*** Was given wrong information by one of the mechanics. The part I need to replace is the timing chain front cover to which the water pump bolts on to. Part is around $700. ouch!
Old May 13, 2010 | 05:04 PM
Tizzy1's Avatar
Tizzy1
It is call the timing chain cover, the part number is 4897571AD and list price is $792.00
Old Jun 20, 2010 | 11:39 AM
Ob1zenobi's Avatar
Ob1zenobi
Haven't gotten to this area so can't speak specifically to this problem- but for whatever it may be worth, sometimes JB weld epoxy can be used to seal or patch an area. Always make sure the surfaces are slightly rough, sandpaper etc & clean with lacquer thinner/ brake cleaner. The red & black JB weld is twice the strength of the 5 minute product, I use both. Use some masking tape etc to create a dam to keep it in the area as needed & let it set up with a lamp or warm area to accelerate curing. Overnight is best. Hope this helps someone.
