ABS issue
Old Jun 13, 2010 | 08:13 AM
kenman1963's Avatar
kenman1963
Default ABS issue
ABS light is on adn I have NO brakes. Is there a reset switch or fuse i need to check ?
Old Jun 13, 2010 | 09:58 AM
vabear's Avatar
vabear
Default ABS Light
I believe there is a 40 amp ABS pump fus ( do not know if ir is under dash or in the fuse box under the hood)e, pulling that should disable the ABS. How is the brake fluid, level, any leaks at wheel cylinders or master cylinder?
Old Jun 13, 2010 | 07:19 PM
NH_USA's Avatar
NH_USA
If it was just a bad ABS you would still have brakes- It is designed to fail in a safe mode.
No Brakes indicates low fluid, or a master cyl problem.
