2004 Grand Caravan Rear Brake Caliper
Old Jun 20, 2010 | 09:13 PM
cswhelan's Avatar
cswhelan
Default 2004 Grand Caravan Rear Brake Caliper
I was attempting to perform a rear brake job on my van when I discovered that the rear calipers are mounted a bit different than what I am used to. It looks like the ONLY mount is the actual caliper slider and there is not a caliper "bracket" that can be removed. Is this correct?
The second part of this question is the actual tool used to remove them. There is a rubber boot protecting the head of the bolt but I got a light in there and it looks like these are a square fitting?? Does anyone know what size square adapter I will need?? Will it need to be an impact version or will these guides come off easily?
Thanks for your help!
Old Jun 21, 2010 | 09:42 AM
Tizzy1's Avatar
Tizzy1
They are a 7mm allen head and come off with just a ratchet. They are the only screws you need to remove.
Old Jun 21, 2010 | 09:47 AM
Tizzy1's Avatar
Tizzy1
1 = Rear caliper
2 = Addapter
3 = Axle
4 = Guide pin bolts
5 = Drive shaft (AWD only)
Old Jul 14, 2010 | 10:53 AM
alexhenryj's Avatar
alexhenryj
I needed to get my calipers off to change out a wheel hub. Thank you for the picture.
