Replacing antenna from 2000 Grand Caravan
Old Jul 29, 2010 | 04:54 PM
David Stembridge's Avatar
David Stembridge
Default Replacing antenna from 2000 Grand Caravan
When pulling off a damaged passenger fender, I found that the antenna was broken as well. The wire going into the dashboard area is still attached. Does that go directly to the radio? How is the best way to replace? An entire new antenna with wire?
Old Mar 16, 2015 | 10:59 PM
Petertoys's Avatar
Petertoys
Smile 2000 Grand Caravan
My Antenna Wire is damaged at The Bottom of the Antenna.The fender is Great. So I am thinking of Installing a Glass Antenna at the top of the windshield inside. I can run the wires down inside the side trim right into
the Dash and into the radio. and just abandon the other one. total cost about $ 11.00.
