02 grand caravan abs&brake indicator light
Old Jul 31, 2010 | 04:52 PM
soupdog2169's Avatar
soupdog2169
Default 02 grand caravan abs&brake indicator light
new here and i have both brake indicator and abs light on they would come on periodically for about 5 days now they are on constant NYS wont pass inspection because brake indicator is on i ran a diagnostisc on abs system says it is valve power failure is it possible that the abs module is causing the brake indicator light to come on as well as the abs light and how can i troubleshoot this i really dont want to spend 400 dollers on a abs computer if i dont need to any feedback would be great thanks
Old Jul 31, 2010 | 05:19 PM
mfahey's Avatar
mfahey
If you can post the codes, I may be able to give you the troubleshooting guide from Alldata.
Wow, 246,000 miles. You've certainly gotten your money's worth.
Old Jul 31, 2010 | 10:39 PM
soupdog2169
well after a few hours of headaches and a few skinned knuckles i found the problem the fuses had power in the box but nothing was reaching the control module when i flipped over the fuse box 3 wires had corroded and broken off so i removed the plug because the local parts store didnt have a new one and spent 8 dollars on some spade connectors and some terminal grease and suprise we have abs and the lights are off and by the way i belive the code for the diagnostics was 10 valve power failure thanks for the offer yeah i have got my moneys worth i paid 2000 for it 130,000 miles ago one of out drivers at work has 366 on his original motor and tranny
