On The Brink of Insanity
You have seen me on here before - and the Problem is still with me!!
2001 Caravan Sport - now on our third instrument cluster replacement, direct from Chrysler. The reason it was changed out in the first place was that the brake light came on and sttayed on - the diode was bad for the ABS - so it was determied that we had to change the cluster.
We have tried another BCM and that made no difference in the symptoms. We are now back to the original BCM.
The cluster is either in one of the following three modes - with no predictability --
Sometimes when the ignition key is removed all of the warning lights in the cluster will illuminate including the flashing low fuel light and then in about 30 seonds to a minute they will all go out.
All grounds in the dash area have been resurfaced and retightened, and I personally cleaned all battery connections, even using dielectric grease on the connections. Battery shows 12.5 volts with engine off.
The self programming has been run more than once.
Neither the dealer or independent shop have been able to solve this problem.
Thanks to those that have had suggestions in the past.
Any additional ideas would be more than welcome.
Thanks in advance.
- Functioning Normally
- Totally "dead" nothing working and all cluster lights out including shift position indicator
- Tach and speedo working, odometer indicator flashing intermittently, low fuel light flashing and fuel needle on E, open doors and open hatch lights on
Thanks in advance.
Tizzy1 - I have always appreciated your professional insights. I will have this checked out. Thanks.
