2003 Dodge Grand Caravan CPM connection anddiagram
Old Aug 6, 2010 | 10:53 PM
dvmdsc's Avatar
dvmdsc
Default 2003 Dodge Grand Caravan CPM connection anddiagram
Good day to all. This is my first post and first question to the members.
I live in the Bahamas, here is no Dodge dealer and I bought a Grand Caravan 2003, 2 years ago. The car served me till a few months ago.
Engine ran hot. I could drive further with adding coolant. A few days later, same thing. I found that the water was leaking to the oil.
The car ran very hot and I stopped it. After 30 minutes wait, it wouldn't start anymore.
Took the heads of and found cracks, and also rests of liquid seal, that had the engine running for the 2 years. The liquid seal probably served the time.
I bought 2 new heads and installed these according the Haynes manual.
The car didn't start anymore. I had the code - bad CPM and bought an exchange CPM. The car ran on it for a few minutes and I noticed the injector rack leaking. Ordered injector seals and fixed it again. (Each US order takes many weeks to reach here. The car is already 4 months dead.)
I tried to start but nothing happened. In the fuse and relay box a 20 amp fuse that powers the fuel pump circuit blew. With the CPM connected that + got a ground. A friend told me the CPM is gone.
I flew back to the US to get it fixed and there they told me something was wrong with the wiring. They said the top harness was bad. I opened it and found no shorts. I need a diagram with the CPM connections on the 2 multi-connectors and if possible also the diagram of the electronics of the CPM itself. Haynes has nothing in it.
The CPM is a 04745860 584011 29. I am afraid when I connect the CPM it will be destroyed again. I need to find this by myself because here are no
qualified people to handle this.
Your help is much appreciated. Thank you.
Old Aug 8, 2010 | 02:32 PM
Tizzy1's Avatar
Tizzy1
Do you mean the engine controller or PCM? Are you sure you didn't pinch a harness putting the heads back on?
Old Aug 9, 2010 | 11:34 AM
dvmdsc's Avatar
dvmdsc
Yes. I didn' t compromise them. Worked very carefully.
Old Aug 9, 2010 | 01:15 PM
Tizzy1's Avatar
Tizzy1
To include all of the PCM diagrams would be like 40 -50 diagrams. Is there a specific area you need? Also need to know if you have an SBEC or NGC, you can tell by how many connectors the PCM has.
Old Aug 10, 2010 | 04:57 AM
dvmdsc's Avatar
dvmdsc
Dear Tizzy1,
Thanks for your reply. In the mean time I became member of all- data that has a good documentation about the missing diagrams.
If you might have the electronic diagram and/or print plate outfit of the secret
aluminium box- it is well appreciated. It might tell me what went wrong.
Old Aug 10, 2010 | 11:00 AM
Tizzy1's Avatar
Tizzy1
There is no internal module diagrams that I have access to, sorry.
Old Aug 11, 2010 | 04:44 AM
dvmdsc's Avatar
dvmdsc
The repair service told me that they would charge next time the computer goes bad. I think I will break the seals to see if they have changed output transistors and to which pins they relate.
I find it very strange: the CPM worked for a few minutes. I stopped the engine,
3 weeks later when I had the parts, i changed the injector seals and afterwards it didn't work anymore. They said it is the wiring.
I cut a complete harness, didn't find no problems, - Just wonder if the CPM has been repaired well? Thank you.
