Door lock actuator problem
Old Nov 10, 2011 | 01:25 AM
Festus9690's Avatar
Festus9690
Smile
Thanks Papaduck for the great info. I am sure your info will be a great help when I tackle this job.
Old Aug 2, 2014 | 12:55 AM
chuck72's Avatar
chuck72
Same problem. See my below post for complete install success. etc.
They should have recalled for those high failure actuators along with drilling a passenger access hole in the right place.
Oh and dealer wanted $600, I believe, to replace them- no way.
Last edited by chuck72; Aug 2, 2014 at 11:46 PM. Reason: below post of mine supercedes what I originally wrote
Old Aug 2, 2014 | 10:48 PM
chuck72's Avatar
chuck72
Actuator install success today on both sliding doors. Per my previous post, I found that the junkyard U Pull sold as is for 18 and change apiece yielded one working passenger side actuator. The driver side actuator did not work just like the originals on my van. Way to go Mopar and yes sarcasm fully intended.
Now, they were cheap from the U Pull yard but they are sold as is and no returns. I was lucky in retrospect getting one working Mopar actuator out of it. Both panels were found intact on the junked van and I pulled them off myself. Both actuators should have worked but as clearly said, it is my opinion after all of this that even new Mopar actuators are overpriced junk so it is as it is. The Dorman aftermarket ones are a way better option in my opinion and much less in cost. One year guarantee too from Advance.
I did have to drill a hole through the door metal on the passenger side of my van because the factory access hole for the screw is completely in the wrong place, meaning not even close; deplorable manufacturing. I didn't have a drill with me at the junkyard so I bashed through the passenger side sheet metal with a big screwdriver and hammer so I could get to the screw.
Installed working junkyard actuator - worked perfectly. Bought Dorman actuator for driver's side on sale at Advance for just over 50. Part # 746-259. Same part is at Rock Auto; same part number, $43.79. It has two arms user interchangeable for right or left. It is a bigger and heavier actuator than the Mopar high failure rate garbage overpriced actuator.
Installing, I had to reverse the hanging orientation of the connector because of how the Dorman is made. The connector on the actuator is reverse oriented from the Mopar; no biggie, just turn the harness connector to fit. The actuator fit fine and works perfectly. Inserting the linkage arm into the hole in the clip and seating the arm into the same clip will be clear after you pop the linkage arm from the overpriced garbage factory Mopar actuator clip
I saw posts from people in browsing saying they couldn't unlock their doors after taking off the actuator which is correct. Reaching into the latch when the actuator is out, you'll feel a horizontal pin which can be moved up and down easily with your finger. Pushing the pin up and holding it up will enable unlocking and opening the door with the upper lock button at the top front of the door; a slightly awkward two handed stretch. I had to figure this out for myself.
So when you install a new actuator, you must make sure that the back slotted arm engages this pin after you've first reinstalled the linkage arm to the clip. You then need to shine a light and look inside the latch from close perspective to the door to get a side view glimpse because you must make sure the pin passes through the actuator arm slot or it will not lock or unlock your door when installed. Do this first, then orient the actuator in. If you did this right, after screwing in the actuator and putting the connector back, it will work perfectly. If the linkage moves but the door does not lock/unlock, take the actuator off and do it again until you get it right.
I hope this helps someone facing the same as the 1A Auto whatever you tube video showing panel pull and Dorman actuator install does not explain anything about the latch pin which if you don't find and understand this pin your install will not work. The arm will not find the pin just by getting the actuator in the guide housing. You must get the pin through the slotted arm first.
Will put the panels back on tomorrow in daylight. I also had pulled a driver's side rain shield when at the junkyard as I had discovered my van lacked the driver's side rain shield after I pulled the panels. I also took the actuator torx screws and lock buttons from the junkyard van as one of my lock buttons fell off into the door during the past two years of manual lock unlock BS.
