Removing the dashboard of a 98 Caravan
Old Sep 9, 2010 | 08:28 PM
scudam's Avatar
scudam
Default Removing the dashboard of a 98 Caravan
I've been having instrument cluster problem like many other Caravan owners. I would like to check out to see if broken solder if the probelm for mine also. I was wondering if anyone had instructions on how to remove the dash (pictures would be very helpful) and how to remove the instrument cluster and where to check for the broken solder. I would really appreciate any help.
Thanks
Old Sep 12, 2010 | 10:38 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I'm assuming you can do soldering on ckt boards? If you can then look for a large light blue resistor. That's where you'll find the "cookage" most of the time.
Old Jun 24, 2012 | 08:58 AM
oldironass's Avatar
oldironass
I need to replace the temperature and mode actuators on my 96 Caravan. Can someone give me a step-by-step procedure for removing the dash?
