2007 Grand Caravan SXT temperature light not working
Old Sep 22, 2010 | 11:00 PM
Ronad's Avatar
Ronad
Default 2007 Grand Caravan SXT temperature light not working
How do I fix the temperature gauge light on my instrument panel? It doesn't light up - all the other panel lights work.
Old Sep 23, 2010 | 09:04 PM
Tizzy1's Avatar
Tizzy1
The bulb is probably burnt out. You just remove the cluster and the bulbs are on the back side. I would suggest replacing all of the bulbs while you have it out. Here are the removal steps for the cluster.
REMOVAL
1.Disconnect and isolate the battery negative cable.2.Remove Over Steering Column Bezel by lifting it straight up with a firm pull.3.Remove the four cluster bezel attaching screws.4.Tilt the steering column in the full down position.5.Pull rearward on the cluster bezel and remove.6.Remove the four screws holding instrument cluster to instrument panel.7.Rotate top of cluster outward.8.Disconnect the cluster harness connector.9.Remove instrument cluster from instrument panel.
