wiring wiper motor direct to power...
Old Jul 23, 2013 | 01:57 PM
cpttuna's Avatar
cpttuna
can you send me the wiring diagram also? I'm having the same problem. george538@roadrunner.com. Thank you
Old Jul 26, 2013 | 08:36 PM
cpttuna's Avatar
cpttuna
Wire in a separate hot fused lead wire. Run the the brown/white wire to source and run the black wire to ground. disregard the red/yellow wire and the green/white wire. this should get you a slow single speed wiper.
Old Jun 10, 2014 | 09:05 PM
electricjoe's Avatar
electricjoe
Default same issue....
I've had a 1998 Plymouth voyager with the same wiper failure. it'll work perfect for weeks then suddenly next use will not even budge. or even worse while running it'll just stop working whenever. I've googled this issue for months. put in a new motor. not sure if it's a switch failure? a ground failure? just lost and never have enough money to take it to dodge dealer to get them to figure it out... any advice? or new wiring idea?
Old Apr 25, 2021 | 08:56 PM
Sliger Sliger's Avatar
Sliger Sliger
Originally Posted by sapporo
just look at the diagram, the diagrams clearly show which wires do each.
infact if you just power over the relay it'll be on. look at the diagrams. if you can read a map, you can read a wiring diagram, it's just an electrical map.
​​​​​​ Maybe I could get you to send that diagram to me too, I have a 2000 caravan same problem,my email hempyone@gmail.com
Old Oct 27, 2024 | 03:31 PM
Captin_Insano's Avatar
Captin_Insano
Default 97 caravan wiper motor
Needing wire diagram
