Question about removal of power steering hose high pressure side on 2003 model
Old Oct 3, 2010 | 11:20 AM
mrjava's Avatar
mrjava
Question Question about removal of power steering hose high pressure side on 2003 model
Hi,
I am trying to replace power steering hose (HIGH PRESSURE SIDE )in my 2003 dodge grand caravan sport 3.3L. It seems I am unable to find way to access and disconnect hose on the steering gear end.
Anyone’s suggestion how to get to it is greatly appreciated? Do I need special key?
Thank you
Old Oct 3, 2010 | 11:33 AM
alvin's Avatar
alvin
FWIW, for 3d gen. models the service manual specifies using an 18 mm flare-nut crowfoot adapter.
Old Oct 3, 2010 | 01:06 PM
Tizzy1's Avatar
Tizzy1
I remove the vapor canister and the mounting bracket and then you can get to it with an 18mm wrench.
Old Oct 4, 2010 | 11:33 PM
mrjava's Avatar
mrjava
Thumbs up Just to say thank you.
Hi,
Thank you very much for your advices, removing vapor canister helped a great deal, all worked well.
Thanks
Old Oct 5, 2010 | 12:07 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Make sure there is a new o-ring on each end of the new hose. Dont get burned.
