Rear heat works with front controls
Old Oct 18, 2010 | 08:25 AM
trophyslayer's Avatar
trophyslayer
Default Rear heat works with front controls
I noticed this weekend that the rear heat does not work when the controls are set so the backset passengers can control the temp
If I control from the front, I can get all speed settings for heat and ac/cold air
but when I switch the controls to allow the rear passengers to control the temp/speed, cold will blow on all speeds but as soon as you get the temp **** to the half way point (even with the speed set to high) no air comes out, but you can hear the blower blowing in the back next to the lift gate
Any ideas,
Thanks for your help,
Old Oct 18, 2010 | 04:15 PM
Tizzy1's Avatar
Tizzy1
Where are you checking for air flow? Maybe it moves to the floor outlet.
Old Oct 20, 2010 | 08:34 AM
trophyslayer
You are right; I was checking the top vents since that was where the air was blowing when operated with front controls and where the cold air blows when operated with the rear controls
But yes the hot air when operated with the rear controls blows from the bottom vents
I should have thought to check there,
Thanks again
