Transmission leak on cold
Old Nov 11, 2010 | 02:06 AM
nitink's Avatar
nitink
Default Transmission leak on cold
2002 TC, AWD with 3.8L and 4speed auto
The transmission leaks oil only when van is cold and funny thing is it throws out 1 oz of oil when I start the van, and leaks come some where from transmission , motor connecting area.
This one baffled local dealers tech, couple of times, they put in dye but still couldn't figure out where leak is coming from.
I am wondering if any one have any suggestion
Old May 1, 2011 | 10:14 AM
AmazeB's Avatar
AmazeB
This post looks like it died. I am here to resurrect it.
I have a '06 Caravan and the same problem: tranny leak when it's cold. The fluid level is above the "hot" mark on the stick when cold, and drops to a little over "hot" when hot. I haven't had the tranny serviced recently, so I don't know how it could be high. I am only looking for the most logical problem, as I want to be ready if the dealer says it is a transmission change - not that they would say that. ;-)
Old May 1, 2011 | 12:35 PM
nitink's Avatar
nitink
In my case problem was in axle seal. As seals get old rubber get brittle and looses some small pieces. when hot rubber expand a bit and could cover leak.
This was very frustrating to locate, chrysler dealers could never diagnose it in multiple visits. but a local independent mechanic found and fixed the issue.
Seal it self was 15$ and mechanic charged me 3hr labor ( however all data shows only 1.5hr for the job).
Good luck
