Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
On the models with ATC, the blower resistor is actually a little control module so it can produce any blower speed it wants instead of the 4 speeds on a manual system. When the blower motor draws too many amps from the bushings getting wet it causes the module to fail in a way that causes the fan to run at high speed any time the key is turned on. The control head can be turned on or off and the blower will continue to run on high speed. The resistor module is around $100 so if I were you, I would consider replacing the blower motor also since the chances are very good that it is the cause of the failure in the first place.
