Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
I have recently replaced the thermostat, radiator (and cap,) and water pump due to different issues. Now the coolant, when full and accelerating, pushes into the reservoir and leaks out the top. What could be causing this issue? thanks!
if it overheated when you had "different issues" then you probably compromised the gasket. when you accelerate, you create higher cylinder pressures which will cause cooling system pressure to exceed cap pressure which pushes coolant into the reservoir
