oil pan removal, question
Old Dec 18, 2010 | 08:30 PM
scotter5's Avatar
scotter5
Default oil pan removal, question
hi. have 06 grand caravan
want to remove oil pan. there is what looks like a tranny brace, 4 bolts holding it. Does engine need to be hoisted when removing brace. i don't have one.
two of the pan bolts are slightly seen under lip of what looks like a cover plate for conver. do i have to remove the plate to get access to these two bolts?
thanks ahead of time for any help!
Old Dec 18, 2010 | 08:45 PM
jumpdrive2's Avatar
jumpdrive2
Old Dec 18, 2010 | 08:57 PM
scotter5's Avatar
scotter5
thanks for responding. this appears to be for a different caravan.. my haynes book 06 caravan book doesn't show hoisting engine is needed. see pg 2b12 if you have the book.
i was wondering if someone did this could show a short to reduce the brace removal and the driveplate cover to remove those two bolts whose heads can be seen.
thanks again
Old Dec 19, 2010 | 01:55 AM
beta2k's Avatar
beta2k
IMHO, don't worry about supporting it, you've still got three mounts holding it up there. I just swapped a transmission in a '99 caravan and it's front mount was under so little load I pulled the through-bolt on the rubber mount by just lifting the engine with my hand. Don't remove the rear transmission strut tho, that's a lot of stress on those top bolts
Old Dec 19, 2010 | 06:58 AM
jumpdrive2's Avatar
jumpdrive2
Instructions and diagram is for a 06 grand caravan with 3.3.
