shaking when apply brakes
Old Jan 9, 2011 | 07:56 AM
joexray's Avatar
joexray
Unhappy shaking when apply brakes
when i apply the brake the caravan start to shake. one tire has some wear. where is the problem? in the disks? tie rod end? where i have to check first? please help me . excuse me for my english , thanks
Old Jan 9, 2011 | 11:39 AM
06powerstroke's Avatar
06powerstroke
If it happens only when you apply the brakes, you have warped brake rotors. If you pull them off yourself and carry them in, the cost is usually $8 to $10 per rotor to have them turned. If they are too thin to be turned, you'll need to purchase new rotors. If you purchase new ones, be sure to clean both sides of the rotor very well with brake parts cleaner before installation. They'll have a protective coating sprayed on them to prevent rusting until they are installed.
Old Jan 9, 2011 | 09:00 PM
joexray's Avatar
joexray
thanks!
