Is this normal?
Old Jan 13, 2011 | 11:49 PM
JETwagen's Avatar
JETwagen
Default Is this normal?
I have a 2010 VW Routan (a.k.a. rebadged Town & Country) and am having some concerns about the sliding door operation. Normally when we pull on the handle outside, the door opens via the power. However, there are times (seems to be when the key is not in the ignition) it does nothing and I have to either use the remote or the the overhead button to open it (mostly noticed on the passenger side.) I had the dealership look at it and they found nothing wrong (they did do an update but nothing has changed) and would just like to verify if there are conditions where the power slide does not opperate or if this is a real problem. FYI, I am aware the driver side will not open at all if the gas cap is open, this is unrelated to that function. TIA
Old Jan 14, 2011 | 07:33 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
only time the sliders dont work is if the disable switch on the overhead console is in the off position. doors will work off remote but not open on power using handles. check that.
Old Jan 15, 2011 | 04:13 AM
JETwagen's Avatar
JETwagen
I'm sure the disable switch is not activated but I will check it tomorrow both ways to be 100% sure.
Old Jan 15, 2011 | 02:32 PM
JETwagen's Avatar
JETwagen
So I ran it through some paces to see when it happens. I found the driver's side works as it is expected to work (don't use that side as often), but the passenger side does not (not even from the button inside except the overhead.) I tested, examined, etc., etc. and I found that the passenger door lock inside is not moving the full motion as the driver side is to unlock the door... off to the dealer to get it fixed. Guess I should've done the testing first before coming on here. I would ask if this is a problem anyone else is having except I think these door cards are unique to the VW (most likely something is binding up and not letting it move.) Thanks anyways.
