Replacing starter on a 2002 T&C
Old Feb 26, 2011 | 09:00 PM
HiVoltg30's Avatar
HiVoltg30
Question Replacing starter on a 2002 T&C
I'm replacing the starter on my 2002 Town & Country (3.8l)
I'm pretty sure I got both bolts removed at the bell housing, but I cant get the starter to come off.
I noticed on the new starter that there is a pin on the mounting plate, is there a trick to getting the starter off?
Does the old one need to be pried off? if so, is there an easy way to do that? there doesn't seem to be much space to work.
Thanks!
Old Feb 26, 2011 | 09:10 PM
22DODGE22's Avatar
22DODGE22
2 15mm bolts and it just pulls out. Make sure you didn't mix up and pull a 15 and an 18mm bolt. the 18 is very close to the 15 but it's for the bellhousing. 13mm for the main power wire nut that's it for fasteners.
