Stuck in 2nd gear & no RPM Gauge
Checked the wiring harness underneath the Power Steering Reservoir and the wiring looked fine. Don't know where to go from here. I had the computer scanned and only come up with the code for Battery Disconnected within 50 starts. I did notice the van running a little rough but very little. I have seen in a few other forums where they talk about the fuse buses get a little rusty, is this true? I have pulled all of the fuses and the relays out and put them back in. Is there a RELAY that might be causing this?
Turned out to be the TCM (Transmission Control Module) for the transmission. The fix cost $435 and now it runs as good as new. The RPM gauge still doesn't work but I can live with that. I was told that the cluster is probably bad and needs to be replaced. Thanks for the help!!!
