panel removal
Old Apr 25, 2011 | 12:26 PM
PJDuramax's Avatar
PJDuramax
Default panel removal
Does any one know how to remove the back panel just above the rear hatch handle?
Old Apr 25, 2011 | 12:30 PM
Tizzy1's Avatar
Tizzy1
On the outside? The panel above the licence plate? Year?
Old Apr 25, 2011 | 04:46 PM
PJDuramax's Avatar
PJDuramax
yes, yes, 2010
Old Apr 25, 2011 | 05:09 PM
Tizzy1's Avatar
Tizzy1
It's held on by 2 nuts from the inside of the hatch.
REMOVAL
Special Tools: Click to display a list of tools used in this procedure
Essential Tools
Click here to launch the form to order any tools you need.
C-4755 - Trim Stick
Originally Shipped In Kit Number(s) 9299, 9299CC, 9299CC, 9300A-CAN.
1.If equipped, disconnect the power liftgate motor link rod from the liftgate pivot (Refer to 08 - Electrical/Power Liftgate/ROD, Link - Removal .2.Using trim stick C-4755 or equivalent, disengage the retaining clips that secure the upper liftgate trim panel (3) to the liftgate (1) and remove the upper trim panel to gain access to the lower trim panel (2).
3.Using trim stick C-4755 or equivalent, disengage the retaining clips that secure the lower liftgate trim panel (1) to the liftgate (2).4.Disconnect the wire connector from the liftgate lamp and remove the lower trim panel.
