Strange SRS Code
I have an airbag light on. I have checked the seatbelt pretensioners, clockspring was replaced, and all connections (I think) checked ok.
I took it to shop today and the only code showing was "Loss of ignition run only". Was it not tested properly or does this message give give a cryptic clue to a fix?
From the diagram, I'd say there is no fuse and the power is fed by the front control module. The cover on the PDC should list what the fuses are for. If none say airbag, then it is a feed from the front controller.
