96 Grand Caravan 3.8l Map Sensor
Old May 13, 2011 | 09:40 AM
SEIndSAM's Avatar
SEIndSAM
Default 96 Grand Caravan 3.8l Map Sensor
Greetings all. I have a trouble code that says I have a MAP Sensor problem. Found one in town and want to replace it. Where is it located? I have the part in hand and don't see anything that looks like it on the manifold, firewall, etc.
Any advice would be appreciated.
Old May 13, 2011 | 10:10 AM
Cougar41's Avatar
Cougar41
Top of the engine on the drivers side of the intake manifold just to the right of the vacuum tree (my term). That's a short metal post with several vacuum lines connected to it. It has a three wire connector.
Old May 13, 2011 | 01:13 PM
SEIndSAM's Avatar
SEIndSAM
Default Thank you
Thank you Cougar. I found it exactly where you said it was. Didn't take 3 minutes to replace once I found it.
