2002 leak detection pump
Old May 17, 2011 | 08:40 PM
gdoogle's Avatar
gdoogle
Default 2002 leak detection pump
I have an 02 Grand Caravan that just started the 0456 code. The gas cap looks fine and I found not obvious hose cracks. The shop did a smoke test and found nothing. The only part they did not test was the leak detection pump. The part and labor was about $350. I thought I'd try one from the junk yard first. I've been told the LDP is located below the breather box and a manual for a 2003 says it's underneath the vehicle about midway back. Does anyone know exactly where the LDP is located on an 02?
Thanks
Old May 17, 2011 | 09:29 PM
steak59's Avatar
steak59
It is inthe Middle of the car, roughly under Driver's seat, by the Rack and Pinion assy.
The pump should be $145 brand new. It should take u no longer than 15 minute to change it.
If you smoke test everything and found no leak, the problem will be the LDP, almost always the case for me.
