dashboard brake and abs light on
Old Oct 19, 2012 | 09:03 AM
johnmara_jtag's Avatar
johnmara_jtag
Originally Posted by rockwvu
sorry to be more specific, i am getting a code:
21 Valve Power Feed failure
I fixed the endes in fuse box like above, is there any other way to determine the cause of abs/brake lights on?
Hi, although you fixed it you still don't have power going through the wires you repaired. Did you check the connections you repaired with a test light and did you check for continuity at the other ends of the wires that you repaired? Did you just resolder the rotten connectors or did you replace them? You basically (as the code states) have a power feed failure. No current detected to the abs unit. Make sure you have power going through the wires you repaired.
Old Oct 20, 2012 | 09:22 AM
rockwvu's Avatar
rockwvu
I removed the ends and cut out corrosion. I soldered to the ends. Where is the other end of the wires? Unplug connector at abs module? How do I test power with battery removed? What pins am I testing?
Old Feb 3, 2014 | 08:29 PM
Van girl's Avatar
Van girl
did you ever figure out the problem? My van is doing the same thing.
Old Jul 13, 2014 | 04:41 PM
Van girl's Avatar
Van girl
Default Dashboard brake and abs light on
Hello is anyone there? I need to know!
Old Jul 13, 2014 | 04:44 PM
Van girl's Avatar
Van girl
Need to find out!
