97 3.3 alternator removal
Old Jun 3, 2011 | 11:30 AM
dannyadams's Avatar
dannyadams
Default 97 3.3 alternator removal
How do I remove the alternator bracket? It appears to be held in place behind the belt tensioner, and I'm not sure how to remove the tensioner either.
Old Jun 3, 2011 | 03:32 PM
Tizzy1's Avatar
Tizzy1
GENERATOR - 3.3/3.8 L ENGINE
REMOVAL
  1. Release hood latch and open hood.
  2. Disconnect battery negative cable
  3. Remove windshield wiper housing, Refer to Windshield Wipers and Washers for proper procedures.
  4. Remove accessory drive belt, Refer toCooling System for proper procedures.
  5. Remove bolt holding top of generator mount bracket to engine air intake plenum
  6. Remove bolts holding outside of generator mount bracket to generator mount plate.
  7. Remove bolt holding top of generator to mount bracket.
  8. Remove generator mount bracket from vehicle.
  9. Rotate generator toward rear dash panel.
  10. Disconnect the push-in field wire connector from back of generator
  11. Remove nut holding B+ wire terminal to back of generator.
  12. Separate B+ terminal from generator.
  13. Remove bolt holding bottom of generator to lower pivot bracket
  14. Remove generator from vehicle
INSTALLATION
  1. Place generator in position on vehicle.
  2. Install bolt to hold bottom of generator to lower pivot bracket.
  3. Place B+ terminal in position on generator.
  4. Install nut to hold B+ wire terminal to back of generator.
  5. Connect the push-in field wire connector into back of generator.
  6. Rotate generator forward away from dash panel.
  7. Place generator mount bracket in position on vehicle.
  8. Install bolt to hold top of generator to mount bracket.
  9. Install bolts to hold outside of generator mount bracket to generator mount plate.
  10. Install bolt to hold top of generator mount bracket to engine air intake plenum.
  11. Install accessory drive belt, Refer toCooling System for proper procedures.
  12. Install windshield wiper housing, Refer to Windshield Wipers and Washers for proper procedures.
  13. Connect battery negative cable.
  14. Verify generator charge rate.
