Radio removal Caravan 2008 (bezel)
Old Jun 4, 2011 | 11:16 PM
realbob's Avatar
realbob
Default Radio removal Caravan 2008 (bezel)
HI, how do I remove the bezel to be able to remove original radio of a Dodge Grand Caravan 2008?
Somebody posted question but no responses...
Thanks!
Old Jun 5, 2011 | 02:32 PM
Tizzy1's Avatar
Tizzy1
up on the underside of the top cover are two screw covers. Pry them down and remove the two screws. Lift up on the top cover and there are 2 screws in the top of the bezel. Remove the 2 screws and pull back on the bezel. You will not be able to remove it but should be able to access the radio. In order to remove the bezel, you need to remove the lower console and there are 2 more screws on the bottom.
Old Jun 5, 2011 | 04:04 PM
realbob's Avatar
realbob
Hi, worked great, very fast. And remove whole bezel in a flash! Just took out the 6 plastic screws at bottom.
2 more questions:
- I have original backup camera. Is there a way to modify wire to make it RCA video so I can use in aftermarket radio? And where is that wire? In back of orignal unit I have antenna wire (which I need an adapter to use aftermarket), a small plug with 3-4 wires (I guess is steering wheel and data to know if door is opened) and standard wire plugs for speakers and 12v.
- Every one tells me that I need a special harness with a control module in order to use an aftermarket radio. If I only plug standard radio wires and antenna they told me I will get errors in computer dash?????
Thanks!
