Slight Shimmy in my 01 Grand Caravan Sport
Old Jun 8, 2011 | 12:44 AM
thaddy1978's Avatar
thaddy1978
Default Slight Shimmy in my 01 Grand Caravan Sport
The shimmy isn't really noticed when at slower speeds, however at highway speeds it is very noticeable...not like the van is going to fall apart or anything, but noticeable. As soon as I take my foot off the gas the shimmy goes away. Any ideas?
Side note: I do have a CEL on and had it checked out at autozone, they said the van was not showing any codes, however. I simply wanted to check to see if there were any new code, as there is almost always the one about the evap system that I have yet to identify or care to fix, as I have read it is not a big ieal.
And on another note...as I am thinking about it and totally unrelated, my temperature gauge doesn't move. What gives? or doesn't gives for that matter?
Old Jun 8, 2011 | 05:33 PM
Tizzy1's Avatar
Tizzy1
First try and rotate the tires and see if the vibration goes away, and check the outer tie rod ends when it's in the air, they go bad quite often.
Coolant full? Once the coolant gets off the sender, the gauge doesn't move.
Old Jun 8, 2011 | 11:59 PM
SimTech1's Avatar
SimTech1
I agree with Tizzy1 rotate the tires and see if the problem moves or goes away. I had a similar problem on a Saturn that I have, when I rotated the tires the problem moved, at the next rotation I noticed that there was something "rattling around in the tire" don't know if it was a valve stem left in there or a weight or what but by then it was time for new tires. After the new tires were on the no vibration and no tire had a rattle in them.
Old Jun 20, 2011 | 01:28 PM
thaddy1978's Avatar
thaddy1978
Wouldn't the shimmy still be there though when I take my foot off the gas if it were a tire problem? Either way, we'll see if this works...two front tires are rated at 51 max PSI, they were at 25. My bad! Back tires were something around 45 max PSI and were sitting at 25 as well. I pumped them up to 45 and 40. Will be driving highway this Friday, I'll see if that takes care of the problem.
Old Jun 20, 2011 | 11:37 PM
tapd117's Avatar
tapd117
Default Dodge Shimmy Issues
See my post, I think you might have issues with warped rotors on your front brakes;
GG
Old Jun 21, 2011 | 09:54 AM
thaddy1978's Avatar
thaddy1978
GG
Oh, I know without a doubt that I have THAT problem. But generally that only manifests itself when braking. The Shimmy comes when accelerating and goes away when I take my foot off the gas. Rattles like hell when I apply the brake at highway speeds.
