1995 caravan ground effects removal
Old Jun 14, 2011 | 04:17 AM
jrdavis81's Avatar
jrdavis81
Default 1995 caravan ground effects removal
I have a 1995 caravan SE that has a factory ground effects kit on it. The sideskirts have now been damaged. I want to remove the entire gound effects from the car the proper way without damaging any of the paint or body. Can anyone help? I can also be reached via email at aplusteacher03@Hotmail.com. Thank you in advance!!!
Old Jun 14, 2011 | 03:27 PM
Tizzy1's Avatar
Tizzy1
DOOR APPLIQUE -
(1) Remove screws holding applique to bottom edge of door
(2) Lift aqqlique upward to disengage from retaining channel
(3) Separate applique from door
FRONT SILL APPLIQUE
(1) Remove screws holding front sill applique to front wheel opening flange
(2) Remove screws holding applique to under side of rocker panel
(3) Lift applique upward to disengage from retaining channel
(4) Separate applique from sill
RIGHT REAR SILL APPLIQUE
(1) Remove screws holding rear sill applique to rear wheel opening flange
LEFT QUARTER APPLIQUE
(1) Remove screws holding left quarter applique to rear wheel opening flange
(4) Separate applique from quarter panel
