2003 Caravan SXT 3.3L interior electrical issue
Old Jun 22, 2011 | 06:46 PM
thewheelman10453's Avatar
thewheelman10453
Default 2003 Caravan SXT 3.3L interior electrical issue
Here's the problem when my van is running everything is fine when I go to turn the ignition into accessory (that's when the car is not running but the vehicle should still have power) nothing works not the dome lights the door locks the radio nothing and then when I go to turn the car on the radio goes back to the factory settings and I have to keep adjusting the settings every time I turn the car off and back on if anybody has or had the same problem and has solved this issue or has an idea on what the problem is please I'm begging you help me out
Old Jun 22, 2011 | 07:12 PM
ShelbyGT550's Avatar
ShelbyGT550
Sounds like somthing is cutting off the constant battery voltage to the radio and other interior acces when the key is off.
Old Jun 22, 2011 | 07:29 PM
gentz's Avatar
gentz
sounds like a failing ignition switch, I would check all fuses first....
Old Jun 22, 2011 | 07:43 PM
thewheelman10453
See that's the thing I checked all the fuses and even the accessory switches...I pulled each fuse and switch individually and they all are good
