1997 Dodge Grand Caravan FWD - Rear Hub / Bearing Removal
Old Jul 4, 2011 | 10:40 PM
Kirbentech's Avatar
Kirbentech
Default 1997 Dodge Grand Caravan FWD - Rear Hub / Bearing Removal
Front Wheel Drive
Disk / Drum
Right-side hub/bearing removal
What is the trick to removing the rear hub / bearing on this vehicle? Per the shop manual, I have removed the rear wheel speed sensor and the 4 hub / bearing bolts.
The service manual lists no other steps after the bolt removal, but my hub/bearing is not coming out. I don't see any other bolts to remove, and the hub/bearing feels like it is welded on.
What simple step am I missing?
Thanks - Kirby
Old Jul 4, 2011 | 11:20 PM
hemi4spd's Avatar
hemi4spd
its simply corroded in place. if the bearings shot and your replacing it anyways, dont be afraid to wallop it with a BFH
or fire a cold chisle between the hub and mating flange of axle
