Speed Sensor & Radio
Old Aug 19, 2011 | 07:44 AM
AcerDeville's Avatar
AcerDeville
Default Speed Sensor & Radio
I have two problems, first I need to know which speed sensor controls the cruise, as my cruise has quite completely.
Next I need a list of the radio wire colors/use, last owner replaced radio and like idiots cut the wires, and now I need to replace the radio again, and want to hook everything up correctly, not backwards like they did.
Old Aug 19, 2011 | 09:31 AM
Tizzy1's Avatar
Tizzy1
CAV / CIRCUIT / FUNCTION. 1-- / 2-X55 20BR/RD-LEFT FRONT SPEAKER (-)X55 20BR/RD (PREMIUM SYSTEM ONLY)LEFT FRONT SPEAKER (-) 3-X56 20DB/RD-RIGHT FRONT SPEAKER (-)X56 20DB/RD (PREMIUM SYSTEM ONLY)RIGHT FRONT SPEAKER (-) 4-E17 20YL/BK-STEP DIM SWITCH SIGNAL 5-E20OR-PANEL LAMPS DRIVER 6-X12 18RD/WT-FUSED IGNITION SWITCH OUTPUT (ACC/RUN) 7-M1 20PK-FUSED B(+)
CAV / CIRCUIT / FUNCTION. 1-X60 20DG/RD-NBS RELAY DRIVER 2-X51 20BR/YL-LEFT REAR SPEAKER (+) 3-X52 20DB/WT-RIGHT REAR SPEAKER (+) 4-X53 20DG-LEFT FRONT SPEAKER (+)X53 20DG (PREMIUM SYSTEM)LEFT FRONT SPEAKER (+) 5-X54 20VT-RIGHT FRONT SPEAKER (+)X54 20VT (PREMIUM SYSTEM)RIGHT FRONT SPEAKER (+) 6-X57 20BR/LB-LEFT REAR SPEAKER (-) 7-X58 20DB/OR-RIGHT REAR SPEAKER (-)
Old Aug 19, 2011 | 09:41 AM
Tizzy1's Avatar
Tizzy1
CAV / CIRCUIT / FUNCTION 1-D1 20VT/BR-CCD BUS (+) / 2-D2 20WT/BK-CCD BUS (-)
CAV / CIRCUIT / FUNCTION 1-X15 16BK/DG-AMPLIFIER GROUND
These are all of the radio wires. As far as the cruise control, does your speedometer work? If it does, the speed sensors are fine, it is another issue.
Old Aug 23, 2011 | 07:54 AM
AcerDeville
Thanks.
