Brake / stop lights doesn't work
Old Aug 30, 2011 | 12:58 AM
saar74's Avatar
saar74
Default Brake / stop lights doesn't work
Hi, I just replaced the transmission and works fine, but now the stop lights doesn't works. I have noticed that the tail lights doesn't works either. I test the stop switch and its ok. The others accessories work fine. The fuses are ok too. Any idea, help....Thanks
Dodge Grand Caravan 02, 3.3 flex FWD 112k
Old Aug 30, 2011 | 09:07 AM
saar74's Avatar
saar74
Default Any idea?
Any idea for my problem, where can I find the brakes wiring diagram? Thanks
Old Aug 30, 2011 | 12:16 PM
Tizzy1's Avatar
Tizzy1
Old Aug 30, 2011 | 12:26 PM
Mrose1977's Avatar
Mrose1977
Did you check the bulbs?
Old Aug 30, 2011 | 01:33 PM
saar74's Avatar
saar74
Yes, I did, they are good. I think that the BCM is the problem, thanks Tizzy1 & Mrose1977. I'm going to check the BCM output to lamps.
Old Aug 31, 2011 | 11:21 AM
Tizzy1's Avatar
Tizzy1
The brake lamps are not controlled by any module. The park lamps are controlled by the front control module grounding a relay. The turn signals are controlled by the BCM. According to your complaint, the brake lamps and parking lamps were inoperative. Why would you check the BCM?
