Brown sludge in coolant
Old Sep 13, 2011 | 10:57 AM
mustafu's Avatar
mustafu
Originally Posted by trophyslayer
mine will do that too, I believe that is the over flow tube, Try pooring slowly, and maybe change the angle you poor the fluid in
as for your leak, where does the fluid show up, on the floor? passenger side? near the tire, front bumper?
Yes, it leaks near the front bumper, across the whole front and middle of the vehicle. It's very intermittent, it doesn't always leak after every drive, but most of the time at least. Might try some UV Dye or rent a pressure tester. Hopefully it's not the radiator =/
