Oil pan gasket
Old Sep 12, 2011 | 01:08 PM
Topher5150's Avatar
Topher5150
Default Oil pan gasket
I replaced the oil pan gasket last year and it still leaks just as bad as it did before. Is there a trick to installing this that I may have missed, or is it just a bad part
Old Sep 12, 2011 | 01:21 PM
Tizzy1's Avatar
Tizzy1
maybe it's not the oil pan. Is the oil coming from the belt end or the transmission end.
Old Sep 12, 2011 | 01:34 PM
Topher5150's Avatar
Topher5150
It's leaking along the length of the oil pan
Old Sep 12, 2011 | 02:30 PM
Tizzy1's Avatar
Tizzy1
Make sure it's not the front crank seal or the front cover gasket. Depending on the year, I have also seen the oil filter addapter leak and look like an oil pan gasket.
