'96 3.8, sudden no fuel condition
Old Sep 13, 2011 | 11:03 AM
mustafu's Avatar
mustafu
Default '96 3.8, sudden no fuel condition
Hello,
1996 GC ES, 3.8, 201,000 miles
My van's been running like a champ mostly for the last month since I bought it, but after returning from a long trip, a few hours later, it won't start. This is what I know so far:
-Runs on starting fluid for a few seconds, then dies
-Fuel pump underhood relay and fuse seem to be ok
-There's no fuel at the rail after cranking (depressed valve at the rail after cranking, no fuel came out)
Is there anything else I can look at it, or am I looking at a new fuel pump? Thanks in advance.
Old Sep 13, 2011 | 12:16 PM
ez1913's Avatar
ez1913
What it could be...
Bad wire on connection to or at the fuel pump.
Plugged fuel filter.
Pressure regulator failed.
Dead fuel pump.
Looks like either way, you are dropping the fuel tank.
It's not that hard when it's empty.
AutoZone shows the pump assy. for my '96 3.3 lt, (should be the same as your's) for $128.
Good Luck,
EZ1
Old Sep 13, 2011 | 04:01 PM
Cougar41's Avatar
Cougar41
Before you drop the tank, you may want to consider the engine management system. If your PCM isn't getting a valid crank or camshaft sensor signal when you crank the engine, it will continue to crank all day without starting. If that signal is missing, the PCM cuts power to the ignition coil, O2 sensors, fuel injectors and the fuel pump. These sensors often fail without turn on the CE light or throwing a code. If you're getting spark and the injectors are clicking, your fuel pump is back on the list.
A quick way to test the pump? Remove the fuel pump relay. Jumper contacts #30 and #87 together on the relay socket. The pump should turn on. If it doesn't either you have a bad pump or the power or ground wire to the pump are open or the 20 amp fuel pump fuse is blown.
Old Sep 14, 2011 | 10:51 AM
mustafu's Avatar
mustafu
Thanks for taking the time to help me out everyone. I was able to use your tips to narrow it down to the pump. I'm replacing the pump and fuel filter today, will let you know how it goes. Thanks again
