GC 2005 - Something is draining the Battery, where do i start ?
Old Sep 23, 2011 | 02:11 PM
Bidule's Avatar
Bidule
Default GC 2005 - Something is draining the Battery, where do i start ?
Hello Guys
Ill try to make it short, GC 2005, 180k km and I have the V6 3.3 engine. It is fairly equipped, including DVD player. The problem started couples months ago, i tought the battery needed to be replaced, but apparently there is something draining it while parked for couple of days. I measured the draw with an ampmeter and i have 900ma, wich i believe is way too high. When i pull the IOD fuse it drops to 70ma. What would be acceptable for this type of vehicule ? No repair was done on the vehicule in the last 6 months, so it's not a pinched wire or something like that. I am electronic technician but i just don't know where to start. If i bring it to Dodge it will cost me an arm to get this fixed.
What would be the most common cause, any help is welcome.
Thanks
Old Sep 23, 2011 | 02:17 PM
22mopar22's Avatar
22mopar22
make sure some light isn't on all the time like glove box, anything plugged into the power recepticals, sounds like you found that it's something on IOD fuse circuit. get a wiring diagram. maybe it's the alternator, maybe a computer, underhood light? map light? visor light? button stuck on power seats? audio system amplifier (s) not shutting down..... these are all common things I've come accross.
Old Sep 23, 2011 | 02:22 PM
Bidule's Avatar
Bidule
Thx mopar, i will defenitely check all those this week-end, sounds like a lot of fun.
I never tought it could also be caused by the alternator.
Can it be a bad relay in the fuse box (under the hood) ?
There is so much stuff on the IOD fuse it will be PITA to troubleshoot !
Old Sep 23, 2011 | 05:24 PM
22mopar22's Avatar
22mopar22
just like how you eat an elephant.
start with monitoring the current draw, start pulling stuff that can pinpoint the problem.
back in the Fiero days, we had a lot of issues with off draw. most times it was the alternator.
Old Sep 23, 2011 | 10:02 PM
steak59's Avatar
steak59
hook up the amp meter, wait 2 minute for all module to go to sleep.
start pulling Fuse off the fuse box one by one, see which fuse you pull will drop the current draw.
