Lower Brake lights non-op
Old Sep 24, 2011 | 05:36 PM
haynosity's Avatar
haynosity
Default Lower Brake lights non-op
Hi all, I have an illusive issue going on with my 98 caravan sport. My lower brake light are not working. The upper middle light does work. I have already checked all of the bulbs, and replaced the blinker switch. Since the upper middle light comes on, I am lead to believe that the pedal switch is good. I also replaced the BCM module because my cluster was not working which actually fixed that issue. any suggestions would be helpful!
Old Sep 24, 2011 | 05:53 PM
22mopar22's Avatar
22mopar22
https://dodgeforum.com/forum/dodge-c...ght-issue.html
Old Sep 25, 2011 | 01:12 PM
haynosity's Avatar
haynosity
Thanks for the link, it pointed me to the right direction. Turns out that I had melted contacts inside of the light housing. All that had to done was to bend up the tabs in order to make contact.
