Multifunction Turn Signal Switch -- Remove Wire Connector
Old Dec 16, 2011 | 01:52 PM
quantass's Avatar
quantass
Default Multifunction Turn Signal Switch -- Remove Wire Connector
Vehicle: 2002 Dodge Caravan SE
I'm trying to test the multifunction turn signal switch WASHER pins. My windshield washer isnt working and i figured testing this first before going thru the elaborate process at dismantling my washer motor.
I;m having troubles removing the wire connector.
I pressed down on the red rab but still the black back end doesnt slide out. I even used plyers while pressing down on the red tab. Am i attempting to remove the wire connector correctly?
Thanks
Old Dec 16, 2011 | 03:29 PM
Tizzy1's Avatar
Tizzy1
You have to slide the red tab backward first, then press it. It is a connector lock.....yay! It should slide back like a quarter inch or so.
Old Dec 16, 2011 | 07:26 PM
quantass's Avatar
quantass
Thank you!
