Remote Control Starter
I have a 2004 Gran Caravan SXT w/3.8L. And I would like to install a remote control starter. Can anyone recommend one that really works on the caravans? Because I can't seem to locate one that works on Chrysler mini vans. Thanks for any help.
Until someone pipes in - take a look at How Do I Buy a Remote Starter for a 2004 Dodge Grand Caravan? You will work yourself to this page...
Hi All,
I install one on my 05 Caravan SE, Idatalink bypass module 60$ from local guy in Montreal + any remote start system (main is compustar) and very easy installation will this bypass system (http://store.idatalink.com/index.php...ct_detail&p=20) all the wires are color coded like the original dodge wires.
I run a tach wire to the distributor for the cold start and everything went perfect. not sure if it will be the same for GC but there website give you all the info you will need for your van.
Good luck with the installation.
