Changing tire and wheel size.
Old Jan 17, 2012 | 03:20 PM
Tilly2's Avatar
Tilly2
Default Changing tire and wheel size.
I just have a quick question. I searched for an answer but found nothing even close. Again, my 1998 Caravan has 14" OE wheels. I obtained a Grand Caravan 1996 that is equipped with 16" wheels and tires. Can I install the 16" wheels and tire on the 1998 with 14"?? The 1996 tires are only about 1 year old and are a fairly aggressive good quality tire. My '98 has tires my Dad put on over the last three years and no two are the same brand and only similar tread patterns.
Any suggestions? Thanks In Advance.
Old Jan 17, 2012 | 06:18 PM
GQ-ROD's Avatar
GQ-ROD
So long as the backspacing is the same and the bolt pattern you should be able to, the only thing is you may have to go with a lower profile tire to clear the front springs. Usually 65 series tires are on 16 inch rims, you may have to go with 60 series depending on your clearance.
Hope this helps
Old Jan 17, 2012 | 06:31 PM
Tizzy1's Avatar
Tizzy1
it appears that the bolt pattern would be the same. The tire size would need to be programmed into the vehicles computor so the speedometer would be accurate.
Old Jan 18, 2012 | 12:59 AM
SimTech1's Avatar
SimTech1
Going from a 14" to a 16" is going to mess with your speedo, you will have to adjust the tire profile and width. I've used this site in the past, it also tells you the approximate difference in your speedo also.
http://www.miata.net/garage/tirecalc.html
Hope this helps!!
Old Jan 18, 2012 | 08:27 AM
Tilly2's Avatar
Tilly2
I went to the site and checked (compared) the tire sizes and there is no difference in speed, the profile is actually a little lower so I am going to try it out. I just hate to get rid of very good tires!!!! Thanks for all of the help.
