2011 Heater issue?
Old Jan 24, 2013 | 11:15 PM
steak59's Avatar
steak59
Originally Posted by JamesRD
My dodge ram runs cold when idling , and runs hot air when driving at normal speeds. Anyone have any input for me?
Sounds like poor flow thru the Heater Core to me, unrelated to this post. Try Flush out Heater core with solvents.
and make sure there are no coolant leak, and check if your Radiator cap holding pressure.
Also, How cold is the Ambient temp in ur area? If you live in a place with -10 degree, it is normal for poor heat at idle. The Outside air might be just too cold.
Old Jan 27, 2013 | 12:01 PM
Darkside 700's Avatar
Darkside 700
I am having the same issue as mcgusto is with the intermittent no heat issue on my 12 caravan. It will happen that either the passenger or the
driver side will do this. I have to shut the heat and fans off and once I had to shut the van down and restart before it corrected itself.
Dealer has scanned computer no fault found.
Hopefully they come up with a fix.
Old Jan 28, 2013 | 02:37 PM
Buggie's Avatar
Buggie
Solution to Heat problem.....The Control Head needs to be re-designed as it is the problem child in the situation and apparently Chrysler is working on it. It can take up to 6 months before the part is made AND it is up to the client to call the dealership to see when the part is ready for install!!!!!
Old Apr 4, 2014 | 07:00 PM
Tracy2609's Avatar
Tracy2609
Default Heater problems with 2012 Dodge grand caravan
Had the same issue with our 2012 dodge caravan. Cold air blowing out of the driver side vent. Used the tip of turning all controls on then off again. This worked some times. Worked with dealership and manufacture without a fix. Chrysler ended up buying back our 2012, but we had to buy another 2014 Chrysler vehicle. The only 2 van choices are the Town and Country or another Grand Caravan. Since we did not want to pay additional out of pocket we had to get another Grand Caravan with less features, but was willing to do this for heat. One week since we got the new 2014 Grand Caravan SXT and it happened again. No heat on drivers side. Hoping Chrysler figures this out soon. It has been a long cold winter.
Old Apr 15, 2014 | 02:52 PM
1wraith's Avatar
1wraith
Mine does this as well. When cycling the **** from hot to cold doesn't work, I pull over and then shut down and re-start. That has always solved it with the exception of my rear vents. They got stuck on cold and the dealer had to replace some vent switch or baffle or something to get the rear to work again.
Old Jan 20, 2015 | 08:55 PM
Kelnmike11's Avatar
Kelnmike11
Same problem here. Won't go away with switching it back and forth. Anyone know if they redesigned the control head yet.
Old Jan 21, 2015 | 08:53 AM
DodgeCACares's Avatar
DodgeCACares
Kelnmike11,
I'm sorry to hear about your concern. Have you recently been in touch with your dealer? If not, I would recommend contacting service dept. and speaking with the Service Manager to discuss your symptoms.
Old Jan 21, 2015 | 10:04 AM
Buggie's Avatar
Buggie
Default Good Luck
When I had my issues I was told it was a software issue not a part issue. I took the company to Arbitration and they had to buy back my Dodge Van. Purchased brand new and problems started happening when it was 6 months old!
