How to get the headliner board out of a 1995 dodge caravan
Can anybody help me I have search every where I possibly can how to remove the headliner board in my van. I already took one of my panels off but the rest of them look confusing some people say you don"t have to take off the panels. If anybody can help me I would highly apprixate it thank"s
HEAD LINING
REMOVAL
(1) Remove first rear seat, if equipped
(2) Remove second rear seat, if equipped
(3) Remove sun visors
(4) Remove A-pillar trim moldings
(5) Remove grab handles, if equipped
(6) Remove inboard sun visor clips, if equipped
(7) Remove overhead console, if equipped
(8) Remove sliding door upper track cover
(9) Remove right quarter trim panel
(10) Remove left upper quarter trim panel
(11) Remove dome lamp, if equipped
(12) Remove push-in fasteners from above rear door opening
(13) Separate head lining from vehicle
REMOVAL
Hey thank"s a lot for the reply back... Just some of my Panel"s on the driver side is harder tore move not sure where to start and my van is just the basic version not the es,le, or grand caravan... If you can tell me how to remove them panel"s it would be great... But thank"s again gives me and an ruff idea where to start
LEFT QUARTER TRIM PANEL
REMOVAL
(1) Remove ash tray
(2) Remove screw holding quarter trim insert to quarter trim from inside ash tray opening
(3) Pull outward at bottom of trim insert to disengage clips holding insert to quarter trim
(4) Lift insert upward and separate quaarter trim insert from vehicle
(5) Remove screws holding lower quarter trim panel to inner quarter panel
(6) Remove rear door opening scrff plate
(7) Separate lower quarter trim from vehicle
(8) Remove covers and bolts holding shoulder harness truning loops to upper quarter panel
(9) Remove bolts holding outboard seat belt anchor to floor
(10) Remove seat belt retractor covers
(11) Remove screw holding coat hook to quarter panel
(12) Remove screws olding upper quarter trim panel to inner quarter panel
(13) Separate upper quarter trim panel from vehicle
REMOVAL
(1) Remove ash tray
RIGHT QUARTER TRIM PANEL
REMOVAL
(1) Remove liftgate and sliding door sill scuff plate
(2) Remove sliding door upper track cover
(3) Pull outward at bottom of quarter trim insert to disengage fasteners olding insert to trim panel
(4) Lift upward on quarter trim insert and separate insert from quarter trim panel
(5) Remove screw holding coat hook to roof rail and separate hook from vehicle
(6) Remove covers and bolts holding shoulder harness turning loops to roof rail and separate belts from trim panel
(7) Remove bolts holding outboard seat belt to floor and separate belt from floor
(8) Remove plugs and screws holding quarter trim to inner quarter panel
(9) Separate quarter trim panel from vehicle
REMOVAL
