What is the Largest 15" you can put on the Caravan?
Hi all, I have searched the site with no luck but I am sure it has been asked.
I have a 2000 Caravan, tires are due.
I also have a like new set of 235-15"s sitting in my shed. Can I use them without any modifacations to the van and on the original dodge stock rim.
It currantly has 205-15"s.
Thank you, John
Thank you, John
Tire size is a reflection of the Width times aspect Ratio(x2+rim dia) So without knowing the aspect Ratio of the P235 tires, its hard to say.
For example. On my Grand Vitara, I replaced the P265-55R 16 tires with snow tires P215-70R 16 as they were about the same height but 2 inches narrower.
If you are looking at replacing a stock P205 70 R 15 with a P235 75 R 15, I would say no. While it might fit in the wheelwell it will impact your braking, speedometer, rub on turning.
