2004 Dodge van HELP
Old Feb 4, 2012 | 01:51 PM
phrigia's Avatar
phrigia
Default 2004 Dodge van HELP
Hi I have a 2004 with the 3.3 and 4 speed auto. Wife was driveing it 2 weeks ago it slammed into second gear and its been stuck there and I cant seem to figure it out. I took it to a transmission shop and they pulled codes p0480, p0700, p0762, p0888, They reset the codes and p0700 keeps comeing back. They dropped the pan changed filter and fluid and told me it wasnt an internal error. I have changed both speed sensors and just got done changing the shift solionide. It is still stuck in second gear and Im short on founds. any advice would.
Old Feb 4, 2012 | 04:49 PM
phrigia's Avatar
phrigia
I took a test light to all the wires connected to the tcm and cant get any power. I also can only get power on 1 side of the relay in the fuse box. I even switched some around and still only poer on 1 leg and nothing on the others.
Old Feb 4, 2012 | 06:14 PM
bjr1a's Avatar
bjr1a
The PO888 code is in this case interesting....this code is triggered when the TCM cant read inputs....At this point I would center my attention and make sure the TCM is not faulty....I am not recommending buying one at this point, but I would advise to get the service number off of module and check for reflashing software or a history of similar complaints....
Old Feb 4, 2012 | 06:27 PM
phrigia's Avatar
phrigia
the sticker on the tcm says it has been updated once before. We have owned it for 2 years and it only has 120000 on it. Dodge wants 100.00 just to look at it used one on ebay for 50.00 is it worth it or should i fork out the full amount if its bad for a new one. it has the same pn# as the one in my van.
Old Feb 8, 2012 | 01:53 PM
phrigia's Avatar
phrigia
I dont know what to do other than drive it into a ditch and light it on fire. I have replaced the computer with a rebuilt and flashed to my vin# changed both speed sensors, changed the shift solionide, and its still stuck in limp mode...........anyone before i make an insurance claim for a total loss
Old Feb 8, 2012 | 02:10 PM
bjr1a's Avatar
bjr1a
If it is ALWAYS in limp mode, then it has to be electrical....I would make sure the TCM has voltage going to it.....On most models it would be terminal 56 ( but that may need to be verified on yours with a wiring diagram) at the tcm connector... also there may be a fusible link between the battery and tcm......
Old Feb 8, 2012 | 02:23 PM
phrigia's Avatar
phrigia
anyone have a wire diagram? my pcm has 4 big blocks of wires going to it.
